C5 Y2K's? I've got C5 Y2Ks that came off a 2000 or 2002 Corvette and they still have the factory run flats and I'm due for another tire. What width are the front/rear wheels? Is there an easy way to tell? I have 245/45/17 on the fronts and 275/40/18 on the rears. I would like to go as wide as safely possible (love the look) but when I view optional plus sizes it goes to just a bigger rim. I'm not looking for something to break my 10 bolt, but I would like to be able to go WOT in first gear... |
measuring tape? pretty sure u can go +20 on the width the ratio should change tho. u dont need wider tires to hook up just better rubber |
Originally Posted by Egg1456
(Post 13165751)
measuring tape? pretty sure u can go +20 on the width the ratio should change tho. u dont need wider tires to hook up just better rubber I know the sidewalls will change, I'd like a lower profile as well. And I just like the look of the bigger tires, but I know the compound is what really makes the difference, I'm thinking about NT555's or INVOs again... Just need the size really so I can figure out how wide I can go, lord knows how much confusion I would cause going to discount tire telling them I need tires for a 2000ish Corvette when I walk them out to a Camaro. |
should work fine just browse sizes |
| All times are GMT -5. The time now is 04:57 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
