LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   Slicks for 16's (https://ls1tech.com/forums/wheels-tires/1277902-slicks-16s.html)
MasterTomos May 7, 2010 02:02 AM
Slicks for 16's
First off, Im going to admit I know nothing about slicks...
I'm looking for a set of track tires (1/4 mile) for 16" stock swirl rims off a 93-94 TA...what's the biggest size you can run without rubbing?
ybaslo1 May 9, 2010 08:52 AM
Depends on what size tire you want, 26" or 28"
M/T E/T streets:
26x10.5x16
26x11.5x16 (never seen this one on a car, you might want to give M/T a call just to see if it will work)
28x11.5x16
MasterTomos May 10, 2010 12:44 PM
again, not being familiar with slicks, would it be beneficial to go with a taller tire?
ybaslo1 May 10, 2010 07:20 PM
What gear do you have? I assume your auto. Do you spray nitrous?
MasterTomos May 10, 2010 07:37 PM
No nitrous, Auto, will be running a 3.23 or 3.42 gear
ybaslo1 May 10, 2010 09:22 PM
Def. a 26" then. The 26x10.5-16 would be the one for you to go with.
MasterTomos May 10, 2010 10:37 PM
thanks much!
3rdgen92maro May 11, 2010 02:27 AM
Are you dead set on getting a pair of slicks...the M/T drag radials hook damn good and come in 255/50/16s(pretty much 26x10.5)
Tommyv8 May 11, 2010 09:05 PM
The M/T drag radial is, for its size, pretty much the heaviest tire ever made. Extra rotating mass is not good for racing. The BF Goodrich and Hoosier drag radials are much lighter.
ybaslo1 May 11, 2010 09:25 PM
Good point.
M/T E/T street = 22lbs
M/T Drag radial = 29lbs
14lbs roatating mass may or may not be a big factor to you. It will only equal a half of a tenth or so.
I'm assuming by the pic in your sig, these are going to be track duty only.
MasterTomos May 12, 2010 02:29 PM
Originally Posted by ybaslo1 (Post 13317075)
Good point.
yes sir, not just for me (because I obviously don't NEED slicks) but for all my buddy's too...we're considering going in on a set together
including:
'00 Supercharged SS
'95 Z28 w/530hp 383 Stroker
'00 Z28 on a 150 shot/bolt ons
'94 TA that will probably end up with Nitrous this year
just needed to know my options before we make a final decision
© 2026 MH Sub I, LLC dba Internet Brands
