Race Star rims! Post pics! - Page 37 - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 11-30-2017, 01:41 PM
  #721
micbegz28's Avatar
Originally Posted by rel3rd View Post
My buddy had that dilemma and took one of the wheels to an automotive paint place and they took some sort of picture of it (as he described it) and mixed him up some paint. Matches great.
Not a bad idea. I wonder if possible to put it into an aerosol can.
micbegz28 is offline
Old 12-04-2017, 01:31 PM
  #722
5.7stroker's Avatar
Is anyone running a 4 piston front brake setup with their 17" racestars? Figured this thread would be a good place to ask.
My racestars are 17x7 with 4" backspacing and I was wondering what options there are. At first I was thinking about the JL9 c7 brakes but those brakes on stock ZR1 wheels which are 17x9 with 7" backspace require a 5mm spacer to clear.
Doesn't look like they will work with racestars. What other 4 piston options are there?
5.7stroker is offline
Old 12-04-2017, 03:56 PM
  #723
Just curious, what size tire are you running on the 17x7s I just got mine and have been on the fence with tire size. Any pics?
MY_2K_Z is offline
Old 12-05-2017, 09:15 AM
  #724
5.7stroker's Avatar
There should be some pics in the links in my signature.
Old 12-06-2017, 01:24 PM
  #725
No Juice's Avatar
Check posts #521, #624, and 645
No Juice is online now
Old 12-07-2017, 07:57 PM
  #726
5.7stroker's Avatar
Thanks for this. Post #624 shows 17x4.5 race stars (I'm assuming 1.75" backspacing) work with the Z06 rotors which are 13.9' part number 1771126 and CTS-V calipers which are part number 1722287 and 1722288.
The backspacing for that 17x4.5 wheel assuming 1.75" has a -25.44mm offset, which means good caliper clearance.
So the question is will CTS-V calipers clear my 17x7 race stars with 4" backspacing, as they are a 0mm offset.
Seeing as how 0mm is the lowest offset they make in a 17x7 race star and post 521 shows a set of 17x7 fit, looks like I'll be good.
The lower the offset, the more clearance for the calipers. The CTS-V sticky states that a wheel with anything less than a 41mm offset will fit. Another thread talks about converting to 2014+ c7 jl9 base brakes with Acdelco brembo calipers- 722586/87 and rotors #1771155, but those rotors are only 12.64"
The larger diameter of the rotor, the more force that is available to stop a wheel.
Old 12-07-2017, 08:23 PM
  #727
5.7stroker's Avatar
Old 12-07-2017, 09:36 PM
  #728
That's for posting pics, they look great.
MY_2K_Z is offline
Old 12-28-2017, 09:48 PM
  #729
krzy_z's Avatar
this looks awesome this is exactly what I'm wanting to do with mine just need to sell my frt 15" wheels
krzy_z is offline
Old 04-23-2018, 08:33 AM
  #730
Originally Posted by IWGF View Post
15x10" w/ 7.5" Backspacing my friend.
IWFG:
I think Draggin10 and myself are wondering what the tire size is, not the wheel size.
What modifications required to fit such as narrowed rear end, roller fender lip etc ?
Some say you have to massage the calipers, some say not. Did you?
EDIT: Oops - questions answered in an earlier post.
dlandsvZ28 is offline
Old 04-24-2018, 09:29 AM
  #731
maybe someone has tried it and not posted. i've seen the question asked, not answered best I can tell in the 19 pages of posts.
looking to do a 17/17 combo w 17x9.5s because mostly street car but looking at 5.25bs for 3" narrowed rear. Would like it to tuck in under the fender, not a fan of it sticking out.
merim123 is offline
Old 04-24-2018, 10:47 AM
  #732
I did have a narrowed Moser rearend on my Camaro - one inch each side.
Back in the day (2005-2007) there weren't a lot of drag wheel options for the Camaro because of the caliper issue and 7.5 inch backspacing.
I have since sold the Moser and went back to a beefed up 10 bolt.
The issue with a narrowed rearend, IMO, is if you want to run two set of wheels - drag and street.
With the narrowed rear end I could run Centerline Warriors with just a 6.5 inch backspacing. The tires would still show outside of the fender lip - but not too much. With the Centerline Warriors I did not have to grind the calipers.
However, when putting the ZR1 wheels back on I had to use spacers, else the tire fit, IMO, was too far in because of the 1 inch narrowing on each side. And also with a spacer you have to have longer studs. Plus I am not a fan of spacers - front or rear. Was always afraid a spacer if it slipped just a little might share off a lug or two.
So if you can find wheels for the rear with a 7.5 inch backspacing and are not looking to stuff a huge tire into the wheel well I would not choose to narrow the rear end again (if you plan to run a set of wheels and tires for the street).
Old 04-24-2018, 03:20 PM
  #733
https://www.flickr.com/photos/183593...7623345499537/
That is what I really like about these wheels. I can run on the street if I want and if really want to go to a 15 tire, I can on these. yes that would mean 6 rims, but at least they will always look the same.
so I want 17/17 to run a 275/40/17 all the way around. and then maybe a 15x8 to run a drag radial if I wanted to.
merim123 is offline
Old 09-21-2018, 04:38 PM
  #734
New wheels 17x9.5 offset +20 p/n 92-795252 dp. With cooper zeon rs3-g1 tires 275/40/17 Had to do some trimming on front liners but very happy overall
Kjduvall is offline
Old 09-24-2018, 09:18 AM
  #735
Big bird55's Avatar
Here is my set. 15x3.5 fronts with 15x8 rears. 275/60 on the rears the fronts have too small of a front tire on them since I got them and I have been trying to find a tire for them. I have been trying to find a 26 in tall front tire that is not a sportsman since that will fit on the rim but since the front is so narrow U have not. Also been trying to find a good set of lugs as the ones that came with the wheels feel cheesy and the chrome plating looks like a **** poor job.
Big bird55 is offline
Old 10-24-2018, 07:58 PM
  #736
Randolph Ziskey's Avatar
Will 285 40 17 work with 17x9.5?
Randolph Ziskey is offline
Old 10-24-2018, 08:04 PM
  #737
5.7stroker's Avatar
People have done it. Speedo will be slightly off.
https://ls1tech.com/forums/wheels-ti...x9-5-rims.html
Old 10-24-2018, 08:38 PM
  #738
Tanx😎
Old 10-24-2018, 08:52 PM
  #739
CoreyD's Avatar
CoreyD is offline
Old 10-24-2018, 08:55 PM
  #740
What size tire
MY_2K_Z is offline
Quick Reply: Race Star rims! Post pics!
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
