LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   Asked before but I'll do it again... (https://ls1tech.com/forums/wheels-tires/1354687-asked-before-but-ill-do-again.html)
ffrh911 Nov 18, 2010 08:41 AM
I'm thinking about getting 17s all around with nittos and using my stock wheels for dr's. My ? Is what would be the best fit dr for the stock 16" wheel and what's the best size to go all around for 17" x 9.5 or 11 i'd prefer them
not to be staggard
cemlsx Nov 18, 2010 09:11 AM
best width for 9.5 wheel would probably be 275 , and id go 305-315 on a 11" . as for stock 16"s i have no idea
bigj2717 Nov 18, 2010 10:41 AM
Wait so you got 17x9.5 and 17x11s and you dont want them to be staggered? Then get the same size rim all the way around other wise do what cemlsx said 275s up front and 315s out back. For the drs size depends on whats done to the car so you need to give some info
ffrh911 Nov 19, 2010 10:20 PM
I have a moser 9" and all the other suspension is basically stock. On the stock 16" wheels what's the widest and tallest tire I can fit?? Hope thts a little better.
And no I'm planning on buying wheels I will get the 11" if they can fit on the front and the back without rubbing with a 285-315 size tire. Get it? Sorry..
bigj2717 Nov 19, 2010 10:33 PM
A 11" rim will probably rub pretty bad on the front. I had 275s on a 9.5 and they rubbed at full lock. For the dr you'll still not saying what's done to the car or what gears you have that all dictates the height of the tire. I run a 28x10.5 slick but you might not need something that tall
ffrh911 Nov 19, 2010 10:55 PM
TSP lt's and true dual x pipe, moser 9" with 4.10 gears and a Detroit locker. Also an aluminum driveshaft. That's about it. There will be a lot more comming in the next few months but that's it for now.
ffrh911 Nov 21, 2010 05:23 PM
Uh anyone???? Just need info about 16" dr's
Mr.z/28 Nov 21, 2010 11:58 PM
For stock 16x8s you can with a 255/50/16 MT, BFG G-force, toyo,
Or if you have a bigger gears out back, you can go with a 275/55/16 MH.
© 2026 MH Sub I, LLC dba Internet Brands
