28x9x15 ET Drag? Will these fit right on 9.75x15 Bogarts? The MT chart says that they are for 8" wheels. I don't think I can get 28x10.5's to fit my wheel well. These would be replacing 26x11.5x15 ET Streets. Thanks, Ken |
I ran a set of those on 15x8's and they looked good. I'm not sure if they will fit on a 15x9.7 rim. I think a M/T ET Street 28x11.5x15 might be a bit wider and fit on that Bogart of yours. I am running 28x10.5x15 M/T Drags on 15x10's, they are the same width as 28x12.5x15 M/T ET Streets. |
John, Did it take a lot of wheel well modification to get the 28x11.5x15 ET Streets to fit? I can't get the 26x11.5x15 ET Streets to hook very well. |
I have not run 28x11.5x15 et streets but in fact 28x10.5x15 hoosier slicks... which are wider. the 28x9x15 et drags will fit without modifications. the 28x11.5x15 et streets are taller and you need to keep an eye on clearance, but they will fit with very minor clearancing. on a camaro you might need to bend in the front inner part of the bottom of the fender well, just deburr it. |
© 2024 MH Sub I, LLC dba Internet Brands
