19 x 10 ZR1 Corvette Wheels _1998 Trans Am Can I fit 4 19x10" ZR1 Corvette wheels on all four corners of my 98 trans am? I read on another thread(https://ls1tech.com/forums/wheels-ti...ay-around.html) that I have to get a 1.25" Spacer/Adapter for it to fit. I know they'll fit the rear but I don't know about the front. |
You will not need a spacer for the ZR1 19x10 . The offsets for the ZR1/Z06 wheels and the regular C6 wheels are VERY different . The 19x10 09-11 ZR1 rim has a 40mm offset . You need the spacers with the OEM reguar C6 19x10's because the offset is 79mm which would tuck the rim in the fender more than stock . As compared to an OEM WS6 or SS rim, with the OEM 19x10 ZR1 wheels on a 4th gen ...you would lose 3mm inner clearence and the wheel would stick out 23mm farther than stock. Here is a good offset calculator http://www.1010tires.com/wheeloffsetcalculator.asp ZR1 19x10 40mm offset / 20x12 59mm offset Z06/GS 18x9.5 40mm offset/ 19x12 59mm offset C6 18x8.5 56mm offset / 19x10 79mm offset F-car 17x9 50mm offset 16x8 55mm offset |
Thanks Thank you! |
Replica ZR1 Wheels not OEM I'm sorry the wheels I'm interested in are Replica ZR1 Wheels not OEM. On this Store Website(http://www.corvetteguys.com/19-inch-...eels-rims.html) it has a 19x10 with 56mm offset and a 19x10 with 79mm offset.Will the 56mm offset Wheel fit all 4 corners of my 98 TA? |
yes sir |
Originally Posted by allantransAm1998
(Post 14513197)
© 2024 MH Sub I, LLC dba Internet Brands
