Question when I put my prostars on my 4th Gen
I bought a set of 15 x 3.5s and a set of 15 x 10 Prostars for my Firebird. First off do I have to change my studs either in the front or both front and rear. Reason I am asking is I am changing back to the stock wheels after summer. And what size spacer do you use in front so the brakes do not rub.
THANKS IN ADVANCE!
THANKS IN ADVANCE!
Location: Your girl's back door giving her the long stroke while you're at work
Some guys run a 5/16" spacer on the front and clear, others still need to clearance the caliper. You'll also need to grind the rears. You might be able to get by with 2.5" studs in the front and you'll need the 3.25" for the rear
