widest rim and tire to fit on 2000 trans am?
#41
https://ls1tech.com/forums/wheels-ti...s-94-bird.htmlhttps://ls1tech.com/forums/wheels-tires/902976-315-30-18s-all-four-corners-94-bird.html
#42
#43
ZR1 wheels with 335/35ZR17 rears and 275/40ZR17 fronts
Had to BFH the rear a little and roll the fenders slightly to keep from rubbing on aggressive turns and accelerating. Had 315's on previously without any BFH or rolling. Not sure if the verts have a little more room in the wheel well or what, but the 335's fit easier than I thought.
My car has the heater hose mod in the rear also and still has the f body lean...
#44
335 ftw
cut, bfh, grind, roll the fenders, tubular adjustable control arms, and an adjustable pan hard bar
Attachment 610645
Attachment 610645
#45
Suggested Tire and size
Looking for some suggestions...I have an '02 WS6 that I recently lowered with a BMR 1.25" drop. I am having my stock rear wheels (I bought the wheel that looks like the ones that come on the '02 30th anniversary edition with the black face/polished lip) widened to 10.5" with a 1" spacer. The wheel shop is recommending a 285/35 setup. Does that sound proper...? As for the front wheels...I am keeping them stock width but am running a 1" spacer to bring the wheel out and am not sure as to what tire or size to run. The car (for now) is strictly for looks and is driven every so often to knock the dust off and keep the miles low. Thanks in advance for your time and input.
#48
