what 18s are you running with c6 z06 brakes hey guys im wanting to put c6 z06 brakes on my 98 ws6 and want to stick to 18s all around i was wondering what wheels i should run that not only look good but also clear those big brakes. i do love a flush offset with the fenders as well :) thanks for the help!! |
Originally Posted by armintheman
(Post 14902179)
great thanks man! what offset are your wheels and what size spacers are you running? also what specs are your wheels if you dont mind me asking |
The offset on the front is 57mm and the rear is 44mm. I know on the front I have a 1/2 inch spacer, I forget on the rear, I believe it is 5/8. You also would have to put on longer wheel studs. The wheels are 19x10 on the front and 19x11 on the rear. Hope that helps. |
it does! thanks bro. and where did you order your big brakes? |
(Post 14914449)
98Custom you put 1/2 spacers on what 19x10 505s? |
Originally Posted by 98CustomSS
(Post 14906864)
© 2024 MH Sub I, LLC dba Internet Brands
