Strano springs camaro, 20" wheels 20+mm offset, WHAT TIRES?
Old 10-06-2011, 09:35 AM
QIK E's Avatar
Default Strano springs camaro, 20" wheels 20+mm offset, WHAT TIRES?
I have some 20x9.5 wheels I'm looking to buy tires for. The tires are expensive so I want to be sure they will work. I have been using a wheel/tire calculator, but I'm still unsure.
I'm thinking 295/25/20 REAR and 245/30/20 FRONT.
Anyone know if that will fit without rubbing. The wheels have a 20+mm offset, and I plan on lowering it on strano springs. I will not be using spacers.
Old 10-06-2011, 10:22 AM
durtyss's Avatar
please dont
Old 10-06-2011, 10:36 AM
QIK E's Avatar
I knew someone would say this...and normally I am opposed to anything over 18s. BUT I have something different in mind. 20s can look good on a 4th gen if done correctly. Check out the LMR/ Kelly Bise Camaro
Old 10-06-2011, 11:27 AM
ls1ya's Avatar
Exactly.... LMR camaro has sickest wheels everrrrrrrr. I couldnt afford to do the 20s correctly, custom offset and backspacing right now. But I've got c6 Z06 18x9.5f and 19x10r coming this weekend till I can switch up again. For the forth time.
Old 10-06-2011, 11:36 AM
durtyss's Avatar
nailed it
Old 10-06-2011, 12:05 PM
QIK E's Avatar
01Blk*SS* has a similar look with 19s. https://ls1tech.com/forums/wheels-ti...t-arrived.html
He is lowered on a koni/strano setup with big wheels and a narrowed rear.
Old 10-06-2011, 12:09 PM
QIK E's Avatar
I want to see this. Let me know when you get them on. What tires are you going to run?
Old 10-06-2011, 04:42 PM
JD_AMG's Avatar
First, why would you run different size tires on the same size wheels?
Second why would you run a 245 tire on a 9.5" wheel? Thats going to be stretched and look like crap.
Also (for looks) I would seriously consider running a wider rear wheel if you are going to go with 20s. The taller you go the more narrow the wheel looks in proportion.
Old 10-07-2011, 10:35 AM
ScrapinBye's Avatar
^^^^THIS^^^^. Couldnt have said it better myself. Speaking from experience, I would def recommend at least a 275 wide tire for the front on 9.5" wide rims. Hell i have 285's on my front 9.5 inchers and it looks great. But as a side note, i had 245's on my last set of rims that were only 8.5" wide. Even they looked too stretched IMO, and those were on narrower wheels. Just tryin to help.
Old 10-07-2011, 12:02 PM
durtyss's Avatar
lol you should sale it and buy a 84 caprice
Old 10-07-2011, 12:20 PM
QIK E's Avatar
That's not durty enough
Old 10-07-2011, 12:22 PM
QIK E's Avatar
The only reason I wanted to do this is because I have 20s from an BMW laying around. I didn't think about the tire being streched, plus it looks like it will be cheaper and safer just to buy a wheel/tire package off the internet. Thanks for the advise and insight guys.
Old 10-07-2011, 12:27 PM
durtyss's Avatar
i got chrome zr1 with tires for 800.00
Old 10-07-2011, 01:26 PM
VinR1's Avatar
I dont know if its been mentioned but 20mm offset wheels may stick out past the quarters and will definetly stick past the fenders...
Old 10-07-2011, 02:13 PM
Leedogg's Avatar
a quick look on tirerak leads me to think your best option it 275/30's all around. I think 20mm offset is going to stick out in the front, but I could be wrong.
Old 10-07-2011, 02:17 PM
ls1ya's Avatar
19x10s are getting a 295/30/19 either bridgestone potenza or michelin ps2 or continental contisportcontact 3 or Pirelli PZero Rosso. front 18x9.5 gonna get... I dont know, its easier to think about than the rear. I didnt really focus on them.
Old 10-07-2011, 02:59 PM
Latch's Avatar
I can't imagine to think how hard an F-body would ride with 20" wheels. Sidewall is your friend.
Old 10-07-2011, 04:19 PM
QIK E's Avatar
Well here are some pics from a month or so ago with 245/40/20 tires. The wheel lips seem to be right at the fenders and quarter panels which is the look I'm going for when it's lowered. The fronts could tuck in a bit more. I am going to go a different route though since I'm not crazy about these wheels, and it's just too expensive of a risk to buy tires for them if they will rub or stick out.
I put these on like this just to see if they would fit and took them immediately back off
18 C6 replica on front 20 on back
20s all around
Old 10-07-2011, 04:28 PM
Latch's Avatar
No offense man but those wheels look awful. What on Earth made you want those wheels?
Old 10-07-2011, 04:35 PM
QIK E's Avatar
haha. I think they'll look good black. I really just bought them too sell them, but I figured if the fit, why not not put them on for a little while. Idk about you, but seeing the same old five spoke wheel combo on f-bodys really gets old to me.
Quick Reply: Strano springs camaro, 20" wheels 20+mm offset, WHAT TIRES?
