17" Alumastars or 15's
Go with the 15. It will look right with the diameter matching the rear. The 15 is also a bit lighter than the 17, your choice of tires is always better on the 15, and as already mentioned both the wheel/tire are cheaper in the 15. The only real case you could make for the 17 is if you needed them to clear your brakes.
Camaro396 what tire sizes are you running? I'm so torn on the 15/17. It looks funny on some cars and good on others. Like it needs a little more tire on the front. Does anyone know if there is a 27" tall 17" front runner?
I like the setup you have now. Interested in the what you have on the rear, are they double beadlocks? What brake setup do you have? If stock did they clear without grinding? Thanks
