I am frustrated - which offsets - please help.
Old Apr 26, 2004 | 04:10 PM
Hagarr's Avatar
Default I am frustrated - which offsets - please help.
I have a 98 Formula. What are the stock offsets of the WS6 rims or even the stock Firebird rims? I am worried about filling the rear wheel well.
Looking at Black Z06 or ROH ZS 17x9 or 17x9.5 rims with 275/40/17.
Would a 35mm offset be too much?
Would a 49mm offset work?
Would a 54mm offset work?
I need rims/tires in a bad way and must decide quickly.
Thanks in advance.
Brian
Old Apr 26, 2004 | 04:16 PM
5POINT7's Avatar
You want to keep it less than 50mm. The lower the number, the more it will stick out. Hope that helps.
Old Apr 26, 2004 | 05:02 PM
Xsta Z 28's Avatar
50 is the max offset to rum, and is OEM.
37/38 mm is pushing the minimun offset to run.
Anything in between typically works.
Old Apr 26, 2004 | 07:33 PM
Squirrelmaster's Avatar
Hi Brian !!!
Tom
