Any BFH/bump stop issues with 295/35/18s on 18X10.5/58mm offset wheels?
I've read the stickys and searched for days, but just curious for those who have installed this setup on a Camaro. Any BFH work or bump stop grinding/removal?
Would a 15mm Eibach spacer reduce or eliminate the need for any wheel well modifications?
Thanks.
Thanks.
Hey, thanks for the response bufmat. Base on your figures, I made a few calculations myself and you are dead on - 20mm.
But, do you think I could get away with the 15mm spacer? And if I went to the H&R 25mm spacer, do you think I would run into issues with the fender lip?
LOL! No Dukes of Hazzardin' the car anytime soon.
But if I did decide to go with the 25mm spacer/adapter just to be safe (guess that would be like moving your tire 5mm closer to the fender - little less than a 1/4"), do you think I would run into fender lip issues with the 295s?
Thanks man. Appreciate your help on this.
Jim
Jim
