Wheel spacers for C5 wheels 65mm offset front and rear?
I have a 94 Formula with an 98 front clip. I just bought some c5 deep dish wheels that are 19 x 10 all the way around with a 65mm offset. So from looking at the wheel sticky I Need 38mm to 48 mm offset for the front, and 38mm to 54mm offset for the rear.
A 1 inch spacer is 25.4 mm which would make 44.6 offset and a .75 inch spacer is 19.05 mm which would make 45.95 offset. Am I correct here?
I was thinking 1 in. for the front and .75 for the rear, thoughts?
With the 3/4" hub spacers the offset is about +46 .
