335/35/17 on 17X11s
Old 11-08-2013, 07:09 PM
DemonicZ's Avatar
Default 335/35/17 on 17X11s
Anyone do this. what mods did you have to do to be able to run these if any.
Old 11-08-2013, 07:28 PM
LPE 403's Avatar
Mini tub....
Old 11-09-2013, 12:10 AM
DemonicZ's Avatar
Originally Posted by LPE 403
Mini tub....
alright 315/35/17 it is haha
Old 11-09-2013, 12:12 AM
LPE 403's Avatar
Lol...a little hammerin, maybe some fender rollin depending on offset.
Old 11-09-2013, 12:44 AM
DemonicZ's Avatar
rear off set is 50. I know 315/35/17 will fit with minor modification
Old 11-09-2013, 01:04 AM
bryan00ssm6's Avatar
All I had to do was hit a two spots with a hammer that were rubbing problem solved
Old 11-09-2013, 02:14 AM
LS6427's Avatar
I only had to hit the inner wheel wells wear my tires BARELY rubbed on hard turns.........with 315/35/17 tires. Literally hit each spot about 4-5 times. 1 minute each side. No rolling of fender wells either. I just removed the bump stops.
335's will fit if you bang a little bit more and use a 1/2" spacer.........
Old 11-09-2013, 02:18 AM
DemonicZ's Avatar
well I'm lowered so that may not be an option. Other than doing a widebody like the 30 beautiful Dick Harrell camaros... but I don't have money for that now so 315/35s it is I may go with a widebody later but definitely no tubbing... daily driver.
Old 11-09-2013, 02:21 AM
LS6427's Avatar
I'm lowered with G2 Super springs. About 2 inches dropped.
No rubbing at all.
Old 11-09-2013, 02:28 AM
DemonicZ's Avatar
No rubbing at all.
on 315s or 335s?
Old 11-09-2013, 06:41 AM
LPE 403's Avatar
They'll fit without a tub, but not without a **** ton of massaging. My response was based on "doing it right" to make them fit. Too much in my opinion just to get a look....but hey, it's you car. Hammer away
https://ls1tech.com/forums/14477926-post4.html
Old 11-09-2013, 10:20 AM
Super Hulk Smash
JakeFusion's Avatar
315s are plenty of tire. The biggest I'd go in the back are 325/50-15 MT ET Radials...
Quick Reply: 335/35/17 on 17X11s
