warning do not use meguiars all wheel cleaner on tt2
do not use meguiars all wheel and tire cleaner on your torq thrust 2's i saw this sitting at my fathers and decided to try it out well it basically ruined my brand new rims idk if i can use metal rouge to re-polish them but they are bad like it ate away the finish I IN NO way blame the meguiar brand it says USE caution on mag and aluminum wheels on the back label but i just saw wheel cleaner and used it just a heads up for you guys
LS1Tech Administrator
Received 1,483 Likes
Which TT2s? Polished finish or PVD? If it's polished, then luster can be restored with metal polish, so long as it's not pitted.
they didn't pitt just heavily tarnished them i guess you could say if you have every seen what happens to stainless or chrome if you live near saltwater over many years thats what they looked like but any way i was able to clean them up but where very dull so i am plasti dipping them black
just give them a good polish and they will be good as new...I have polished aluminum wheels that were 30 years old and rough as a sidewalk with scotch brite pads and mothers aluminum polish (there are better polishes out now, currently been using Blingmaster but Adams seems to be the new best)
you could probably get them done in about 20 minutes per wheel with a power ball
http://www.theruststore.com/Flitz-P2...ZN4aAqU28P8HAQ
I used this on my TT2's inbetween polishing to clean them. Had no problems with the finish. They use to sell it at Summit I couldn't find it anymore.
Some metal polish should get them clean once again. Mothers makes good metal polishes for over the counter.
All wheel and tire cleaner should only be used on factory clear coated wheels or aftermarket clear coated wheels as well a being ok for chrome.
For aluminum the only wheel cleaner that you should use is either this or soap and water if you have maintained them very well.
The color changing wheel cleaners are also ok as they have a PH around 7. But as always read the instructions on how to use them.
I would recommend P21 polishing soap (http://www.autogeek.net/p153.html) and P21S Multi-Surface Finish Restorer (http://www.autogeek.net/p2mulfinres.html). Then follow up with a sealant such as BLACKFIRE Wet Diamond Metal Acrylic Sealant (http://www.autogeek.net/blackfire-al...l-sealant.html) or Surf City Garage Diamond Edge Wheel Wax (http://surfcitygarage.com/car-care/t...wheel-wax.html) which you can pick up locally at pep boys.
