iForged valve stem seal?
Where the valve stem comes through the barrel that seal is leaking and causing me to have to put them up every time I drive the car. I tired searching iForged site, couldn't find anything other then replacement ones for $75. I'd rather just replace the seal.
Anyone had any experience with this or know where to get replacements. Otherwise I'll call iForged Monday. Just had some time over the weekend and figured I'd give it a go.
I'm guessing that they are the screw in type, if so they may use the same seal as TPMS sensors. Also, I have seen chrome replacements at my local NAPA ~$20 for a full set of four with caps.
You will need to break the tire off the bead in order to change the seal or stem.
This is a link to Jegs website, and a listing for metal valve stems. Even in you need to buy the whole set of stems, just for the seals, it's only $10-12...
http://r.search.yahoo.com/_ylt=A0LEV...U9ck.I6ut10d4-
