Help me pick a wheel/tire combo
So it's time for me to get a new set of tires, thought would be a good time to replace my stock rims as well. So many options out there, don't really know which is best for me. Was thinking of getting Forgestar F14's from Strano's website. Only set of lightweight rims I found that was less than 2k. Then I thought to couple that with a set of NT05. Thing is both of these come in over 20 different variations and don't know which I should get.
Car will be weekend canyon carver with a couple auto-x event here and there.
It really depends on the tire brand/model since for some unknown reason there can be a noticeable difference between some tire widths depending on the brand/model.
Fir example, I've had 275/35/18s Pirelli pzero rosso asimmetrico tires that weren't any wider than the factory 245/50/16 Goodyear Eagle GS-C tire that came on my car.
Here is my setup (Sara 2001 Z28)
Foregline rims (+46mm offset 18x9.5) with Michilen Pilot Sport 285x35zr18. Good fit no rubbing:
I would go at least 18x10, these cars can fit a 315 no problem up front.
Since you want to auto-x in a street tire class, I would look at a 275/35/18 bridgestone re-71, Hankook rs-3, BFG rival, or dunlop star spec. I've used the nitto nt05 and its a great street tire that lasts a long time even with hard use, but they really don't have that much grip.
You have to balance your goals. The nittos will last longer and are cheaper, but the other tires mentioned will be magnitudes more fun when autocrossing or pushing hard around some corners. I would definitely second the recommendation above about the 18x10 deep concave. Forgestar makes a great wheel, incredible quality for the price.
Hell, if you really want to get crazy you could do 18x11 deep concave all around, and some sticky 315's. Tires start to get expensive though.
Another option would be to put some all seasonals on my stock WS6 wheels and use the Forgestars for the track.
Have you heard anything about B-stone releasing this tire in the 295/35-18 size, even though it would not be ST class legal??
Been a while but finally ready to pull the trigger on some F14's. Current plan is to get four 18x11 rims each paired with 315/30/18 Toyo R888's.
Only issue now is choosing what offsets to run. Read over on frrax that for 17x11 rims, 36mm is the ideal offset for both front and rear. I'd imagine for 18's it shouldn't be any different, right?
Anyone else know what sort of offsets to run for a 18x11 rim on the front?
Douchebag On The Tree
It's not just for turn-in, but it also makes the car MUCH MORE balanced handling wise, since the BIG, FAT meat rear, smaller front staggered set ups SOOOOO popular around here for 'looks' and/or drag racing works AGAINST you when turning left and right (and braking for turns repeatedly) in these cars.
Remember, MOST of our weight (54%-58%, depending on how much weight one pulls OFF of, or adds onto the front of the car) is on the NOSE of the car.
The iron blocks also so popular on here ONLY make this worse yet.
If you've got most of your weight over your front tires, seems pretty obvious to me you should have more rubber as well if you want to grip.
Anyway I've ordered four F14's in 18x11 all with a 40mm offset. Firebird's seem to have a little more clearance than Camaro's so I may get away with just rolling my fenders and a BFG without any need for spacers. Still debating whether the Rival S are worth $400 more than the tried and tested R888 for a street/track tire...
I would also think that the Rivals would be better in the wet (IF that is a concern) given their 'sipier/treadier', more cut tread pattern, and wear at least a little bit better, given their 200 tread wear rating (but this does NOT always hold true).
From what I've heard, the Rivals do not get as 'greasy' once they get very hot on road courses like the 888s have a rep for doing, but up until that point I would expect the 888s to be stickier, given their soft, 100 tread wear compound, and much more slick-like tread pattern.
