Looking to buy some c6 corvette rims
Hello found a nice set of c6 take offs fronts 18.5x+40 offset
Rears are 19x10 +79 offset
Will these fit my 00 camaro SS? First time buying rims
Planing on powder coating them black to match my rig for 600 for the set
yes they will fit. you will need a hub centric adapter though. 1.25". also just something to consider if you are lowered, rears end up being slightly taller than stock by 1.2" 245/50/17 is about 25.7" tall vs 285/35/19 at 26.9". you will need to get your speedo recalibrated to account for this. I haven't rolled my fenders, and I am not on heater hose mod and one side will rub occasionally. but im trying to find a sweet spot on my adj panhard to help with it.
Yes they will fit with the right spacers BUT you'll notice reduced traction upfront. The benefit of the 285's in the back over the stock 275's isn't really noticeable but the 245's up front instead of the stock 275's is really obvious. The car doesn't brake nearly as hard as it did before. If I was to do it again I'd probably go with the 19's all the way around.
400$!
C6 GM ORIGINAL WHEELS IN GREAT CONDITION. THEY CAME OFF A C6 DUE TO WHEEL UPGRADE. I'M ALSO REMODELING SO I NEED THESE GONE ASAP. HAS SMALL SCRATCHES AND ONE WHEEL HAS SMALL CURB RASH THAT CAN BE FIXED.
HAS THE STANDARD EAGLE F1 EMT/RUNFLAT TIRES ON THEM. BOTH REAR TIRES ARE IN GOOD SHAPE WITH SOME THREAD LEFT. BOTH FRONT TIRES NEED TO BE REPLACED.
PICK UP ONLY. I'M ALSO WILLING TO MEET UP ANYWHERE IN LOS ANGELES AT A SAFE PLACE. JUST PM ME YOUR AREA AND I'LL PICK A SAFE PLACE TO MEET. IF YOU KNOW ANYONE IN LOS ANGELES TELL THEM TO GET IT FOR YOU AND SHIP IT TO YOU BECAUSE I DON'T HAVE TIME FOR ALL OF THAT, SORRY THANKS.
