Looking for a winter tire that will get WOT traction.
Hey guys, I'm wanting to get a set of winter tires for the back of the car that will not be too dangerous in the event I decide to do some WOT pulls at high boost. There is a set of MT 275 et pro's on the car right now. Any recommendations?
Thanks.
Thanks.
LS1Tech Administrator
Received 1,489 Likes
Depends on what sort of winter conditions you are facing. In my region, the only way to get proper winter traction with a 4th gen is when using a true snow/ice tire, and none of those are well suited to WOT action or high speed stability.
LS1Tech Platinum Sponsor
The Tire you seek does not exist. Things that make a tire grip well in the winter oppose things that make summer drag radial style tires hook up. Tires that are very good in snow and ice include the Bridgestone Blizzak or Michelin XICE series. They are not performance rated and trying to hook up/burnout will lead to there quick end.
Lol, not too much snow. But it does get cold out here in Lubbock. I ran the NT05r on my heads/cam car and they do ok. It was probably a stupid question in the first place. Traction with turbo cars is hard to get in the heat, let alone the cold. Oh well.
Thanks for the input guys.
It may be regional with the injectors as I haven't had that problem however over the winter months I run the tank dry and put 93 octane in and let them go through the injectors every week or couple of weeks. Since you are in texas stop dicking around and get some Pro Radials. You'll be fine.
IF so, what temps ARE they good for (to have 'acceptable', and not dangerous cornering/braking traction?
Question; are the UHP all seasons (BFG g Force super sport all season, Michelin Pilot AS3, etc.) compounded for down to 10-15* F ambients in bone DRY weather, or do even they turn into blocks of ice at those temps??
Those mentioned are probably, much better at low temps, but at 10-15 I would think any rubber compound is going to be way down on potential grip.
