18/15 Weld RTS Combo - Updated with Pics
MWC - no extra cost to have it narrowed. They were the most reasonable price I found for a S60. I have full adjustable suspension on the car, not sure if that is required, but it made it SO much easier to install when you can lengthen or shorten any suspension piece as you go. Overall, it was very bolt-in and only had to modify the torque arm bracket and e-brake bracket to fit. Brakes just require the ls1 backing plates to be pressed on, after that it's standard procedure.
Did you have to modify the brake lines?
this looks absolutely perfect. I'm hoping my rear end gives out sooner than later so I have a reason to go with the narrowed rear and those 15" welds....with 18's in the front
S60
How much narrowed per side, 2''? 3"? And whats the backspacing on the wheels? 5.5? 4.5?
This was much more tucked than I expected, which was a pleasant surprise. T/A's have wider rear fenders, so that also helped.
Overall, I'm very happy with it.
