Vision 571 Sport Star / Jegs SSR Star wheels 17x4.5 15x10 4.5bs Trans Am WS6
Old 05-05-2017, 08:10 AM
Ernie W's Avatar
Default Vision 571 Sport Star / Jegs SSR Star wheels 17x4.5 15x10 4.5bs Trans Am WS6
I recently installed a set of Vision 571 Sport Star wheels on my Trans Am. Ordered them from Summit Racing. Same wheel as Jegs but we're cheaper at the time. I think they are same price now.
Front's are 17x4.5 with Mickey Thompson Sportsman S/R 26x6-17. Rear are a 15x10 with 4.5 backspacing and a Mickey Thompson 275/60-15 ET Pro radial. My rear is a 8.8 I built that has been narrowed 3" per side. Midwest Chassis tunnel mounted torque arm, lower arms, panhard bar. Founders Performance panhard relocation bar. I need to clearance the wheel wells some just to be safe and trim bumpstops brackets off. Bumpstops have been unbolted for now.
I'm pleased with the outcome of it. Wheels were around $450 total. I had some Dark Stars but sold them to get these.
Old 05-05-2017, 09:11 AM
MM98's Avatar
Looks great man! Get some drilled rotors & paint the calipers now!
Old 05-05-2017, 10:06 AM
92ZZ3RS's Avatar
looks good
Old 05-05-2017, 06:32 PM
94Z28Joe's Avatar
I just ordered the same setup for my car except I went 15x8 in the back with a 275/50r15 ET Street S/S waiting for the wheels to come in. I'm going to be selling my C7 Z06 Reps when I get them.
Old 05-05-2017, 06:39 PM
handyandy496's Avatar
Are those the 30" diameter tires?
Old 05-05-2017, 08:53 PM
Ernie W's Avatar
28" radial. I'm curious to see how it does as a 28" tire may hurt me being lower power N/A.
Old 05-05-2017, 08:55 PM
Ernie W's Avatar
That's my next project. I may upgrade to the C5 front rotors too. I haven't decided what color to paint the calipers but it will probably be silver, black, or red.
Old 05-06-2017, 01:38 PM
Your setup looks awesome! There is a Mt 295-65-15 radial ss. I would love to try a set as I cant get any reliable 60ft's. But will they fit? There not super wide.. But they are 30"s
My tires Nto5r 315 35 17's 25.7 dia only hook once is a while or not at all babying the throttle. If I hit it hard letting off the brake at 3000rpm It starts to go and then the trans goes 1234 then back to 2 for 1.88 60 ft's. Its a rush. lol. But there's nothing better than a perfect hook on a perfect track. My best on the Nto5r's 1.60. I would hate to go to 28's and not hook but with the 30" + 4:10's is like 3:55's. so I would have to change to 4:56's
28's = 3:80's. How are the Mt 28"s on a really hard launch? Might not even need going to 4.30's If they can stick on a not so perfect track.
Old 05-06-2017, 02:37 PM
I have a pair of ctsv 4 piston calipers with 24" Z06 rotors drilled, slotted and are no rust silver plated ready to go on but if u don't like the 28"s for gearing we could make a trade.
Old 08-01-2017, 08:04 PM
89ROC-Z's Avatar
Do you know the weight of the rims? Also, did the rear 15x10's clear the stock brakes without any grinding?
Old 08-01-2017, 10:19 PM
Omega Doom's Avatar
so your specs on the rears 15x10 4.5 bs would that fit a stock rear TA and did you use spacers ???
Old 08-02-2017, 08:22 AM
89ROC-Z's Avatar
For a stock 4th gen you'll need 7.5" BS.
Old 08-02-2017, 08:24 PM
Omega Doom's Avatar
so if they only sell it with the biggest BS of 5.5 then ill need spacers?
Old 08-02-2017, 10:17 PM
89ROC-Z's Avatar
No, 5.5" will stick out 2" further than a 7.5" BS. You would have to machine off 2" of mounting surface, which won't work
Old 08-15-2017, 01:22 AM
LSxPwrDZ's Avatar
Any chance I could get you to measure how big the counter bore where the lug nuts go in is? As in the recess from the face of the wheel, that diameter? Trying to figure out if I can machine or make 5/8 studs work with these. Need a cheap set of street wheels.
Old 08-15-2017, 09:48 PM
Omega Doom's Avatar
you mean if I use spacers or just in general?
Old 08-16-2017, 10:32 PM
vincez28's Avatar
hi...is the center bore 3.272 in.
off set -24mm (front)
backspace 1.750 in (front)
off set -25mm (rear )
backspace 4,5in (rear)
thanks
Old 08-17-2017, 07:41 PM
5.7stroker's Avatar
On a stock rear, 5.5 will stick out 2 inches. If you use a 5 mm spacer, it will stick out 2 inches, 5mm. If you use a 10mm spacer, it will stick out 2 inches, 10mm. The only way you will get wheel that is 15x10 with a 5.5" backspace to sit flush is if you do what the OP did and shorten the rear end.
Old 11-16-2017, 09:25 PM
Big bird55's Avatar
Ok did the rears clear the brake caliper without having to grind. Been looking for a set to put on my he for a while
Old 11-16-2017, 10:01 PM
5.7stroker's Avatar
On the race star 15x8 you have to grind a little. Probably on the 15x10 also.
Quick Reply: Vision 571 Sport Star / Jegs SSR Star wheels 17x4.5 15x10 4.5bs Trans Am WS6
