Keep bending wheel lips; Tire Recommendations
Hey Guys-
So I need some advice/recommendations on front tires for my Weld RT-S 18x10's. They are currently wrapped with Toyo R888 295/30's (less than 500 miles on them) however, I have slightly bent the out lips on both fronts on 2 separate occasions already.
All have been due to very slight imperfections in the road. I feel this is mainly due to the very short and extremely stiff sidewalls on these tires, along with a stiffer suspension (BMR springs/Bilsteins) and obviously the vehicle weight up front.
What brand and size tire would you guys suggestion I replace them with so I don't run into this issue again after having the wheels straightened? Something that will complement my rear tires. (315/30r18 (R888)- 25.5")
Would 285/35" give me enough side wall cushion? What brand/model has a less stiff sidewall? Anyone have experience with Sumitomo HTR Z II's?
Here is the mentioned bends...
Front tire pressure is at 30lbs. If it was just one, then I consider the possibility of the hoop being defective but both my fronts are bent. I had them straightened and now have both fronts bent again. I didn't hit any potholes nor anything I felt would have been the culprit. I really feel the stiff side walls are the problem. I'd hate to think weld wheels are that damn fragile.
With that said, would a 285/35 with a softer side wall really help over a 295/30?
You could try wider tires, but there is no road rash on those bends to indicate contact with the rim caused damage. I think you should speak with weld or the manufacturer they may have better insight onto why they are bending
How much do they charge for the straightening
I may try lowering the cold tire pressure to 26-27psi and see if that helps any. Warm/hot around 30'ish, rather than 30 cold and more so when making runs on the highway.
Many Weld wheels are designed to bend instead of break, good for the track (They can be straightened) Not as good for the street as they can bend. Also a lot of their wheels are designed for min weight, which means thinner material, I've run them a lot of sprint cars, they are very tough and we have straightened them more than I'd like Ours are the 3piece ones with beadlocks. I think your actually compressing the tire till the sidewall folds and bending the rim.. Low profile tires on heavy cars... yep.. BTDT Got the bent 16's for grinder stands in the garage..
See that's the thing, same here. I have 315/30r18 R888's on 18x11's in the rear and they are perfectly fine going over the same road conditions that are bending the fronts. I think pdxmotorhead is right, the heavy nose mixed with a low profile stiff tire is the main culprit. Just want to know if a 285/35 would be enough sidewall to help prevent this from happening again before spending more coin...or...am I just SOL and have to keep spending $200 to straighten the two fronts every time.
I think the issue here are the wheels.
What do you guys suggest for alignment settings? Car is lowered on BMR springs. (26.6" from ground to top/center of front fender lip)
My thinking is you may want to run a few degrees negative camber to ride heavier on the inside of the rim.
I'm not sure how my car was aligned, but for ten years now my car has had camber wear on the outer edges of the front tires, where as most lowered cars seem to ride heavier on the inner part of the front tires.
You may want to check to see how the tires are wearing out as well. If they have less tread on the inner as opposed to the outers
