Traction
Old Jun 24, 2017 | 10:35 AM
BeasstZ28's Avatar
Cool Traction
I wanna start running a little wider tire on my 02 z28 ss camaro but also dont wanna grenade my stock rear. Ive got 275s on it now and they arent enough. Whats the widest i could go on the rear?
Old Jun 24, 2017 | 01:25 PM
HCI2000SS's Avatar
315 on and 11' rim is about the widest
Old Jun 26, 2017 | 06:38 AM
leadfoot4's Avatar
Traction isn't defined strictly by tread width. Rubber compound is also a determining factor.
Old Jun 26, 2017 | 07:51 AM
LS6427's Avatar
I used 315's on my factory 17 x 9 rims......for 12 years. They handled perfect, they wore perfectly even, and they look great. Much better traction. You will only need to bang in the inner wheel wells with a hammer for literally 20 seconds per side, because they will rub a little bit when you take corners.
315/30/17 Nitto 555 Extreme tires are a great choice. Great in wet conditions too. (((Not the 555R drag radial)).
Cheap too.....
Old Jun 27, 2017 | 07:14 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
As in the post above^^^ by LS6427,I also run 315/35/17 on the stock 17x9 rims for 9 years now. Mine are the Nitto drag radials.
But getting back to the 'traction' topic by the OP,2 different 275/40/17 tires can have totally different traction characteristics, Rubber compound,tread block design all play into the traction aspect.
