CCW Classics 18x9.5 ET40
Im looking into some CCW Classics for my O1 WS6, currently running on TT2 17x9.5 front and 17x12.0 rear with 315 tyres - they fit but room is tight and i want to lower with some 1.25 inch lowering springs.
i don't know the offset of the rear wheels, but they stick out of the arch by around 8mm.
Ive checked the sticky up top and ET40 is listed as being ok to fit front and rear- how much does an ET40 stick out of the arch over a stock ws6 wheel?
TIA
TIA
You need to ask the member on here, Dopefedz. He has like 15 sets of CCW lol. He could probably point you in the right direction to find some.
This is a good offset calculator to use
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
quick search showed a stock ws6 wheel being 17x9 with a 50mm offset. if you plug in those numbers and the numbers for the new wheel you are asking about it says you will gain 4mm from the inside of the wheel to the strut housing and the outer edge of the wheel is going to being 16mm further out than the WS6 wheel sits.
I have 285/35 on 18x10.5 +38 with no rubbing issues on my camaro which has narrower qtr panels than firebirds.
this tool is great to give a visual of your needs
https://www.rimsntires.com/specspro.jsp
Hi Dojob,
Any pics of your car larger than your profile photo?
Would be grateful if you could post a few. Also - I take it that your 285/35's are all the way around? not just the rears?
Cheers
James
