Sizing for 19inch CCW's Hey guys, I'm planning to buy a set of CCW sp500's for my lt1 camaro. Looking at 19x8.5 with 245/35 for the fronts and 19x10.5 or 11 with 305/30 Continental extremecontact sports for the rear. I'm also doing the cts-v2 front brakes. So what offsets do I need? The rears should be pretty straight forward, but the fronts with the bigger brakes is what I'm not sure of. Oh, also lowered with strano springs. BFH and fender rolling expected. |
You need a minimum backspacing of 7.75" both front and rear. Fronts will look better with less backspacing. To insure wheel clearance over front calipers, buy wheels with an inch less backspacing than what you would consider ideal, and add a 1" hubcentric spacer. |
Originally Posted by stp001
(Post 19721109)
CCW will make you wheels with custom offset where you won't need to run spacers. I'm running 19x8.5 wheels up front with 40 mm offset 245/35/19 tires and they fit perfect! |
I run 19x10 AND 19X11s with 275/30 and 305/30s don't ask me the offsets cuz I don't know lol, just call CCW I'm pretty slammed also, no rubbing issues https://cimg6.ibsrv.net/gimg/ls1tech...0c6823be91.jpg https://cimg7.ibsrv.net/gimg/ls1tech...f22b1ff51f.jpg https://cimg8.ibsrv.net/gimg/ls1tech...f669464083.jpg |
| All times are GMT -5. The time now is 07:27 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
