Biggest Tire That Will Fit?
Old 05-14-2018, 10:41 AM
Black_Diamond_WS6's Avatar
Originally Posted by Nick.H
My friend runs a nitto 555r on his bolt on LT1 trans am. But he's smart and runs a drag pack. 15's all around. 15x8 in the rear and 15x4 in the front. Rear Tire size 275/60r/15. Dead hooks every time. And we lost a ton of weight from his 18's. It outruns most other bolt on Lt1's because he and I went ahead and addressed rotating weight first. LS1 driveshaft, drag pack, lighter flexplate went a long ways. Again, if you're after the looks, go with the giant tires and rims. If you want performance, use the smaller wheel/tire setup that still hooks. Best of luck
Nick, the problem isn't so much in the tire. If our roads around here were worth a ****, and if the weather were ever consistent, I'm sure my 285s that I have now would be perfect. But, they aren't worth a ****, and weather is never consistent. Those are the main issues
Old 05-14-2018, 08:02 PM
Nick.H's Avatar
Even with poor surface conditions (unless you mean mostly gravel), at your power level you'd be able to make a 275 or 285 hook with a good burnout and launch. Are you currently on a street tire? If so what kind? I remember you saying you didn't want to address suspension, but that is a huge part of getting traction, especially in drag racing. More important than the tire size or brand, actually.
There are some folks around me who have raced on awful surfaces and hooked fine with a good tire, wheel, and suspension setup. I only speak from experience. I had huge drag radials on my car once upon a time when I had around 375whp and it probably didn't do anything but slow me down. If I had taken the time to learn how to launch my car well, and fixed my suspension, I'm sure the 285's I had would have done fine for me. Again, this is just my advice. If you don't think it'll work for your situation then don't do it. However, I can almost guarantee that if you work the launch on a good 275 drag radial, you'll hook with no issues.
Old 05-15-2018, 10:31 AM
Yeah, there's gravel on almost any road in our area. Even the paved roads, most have a small amount of gravel tracked onto them. And most of the racing we do is very impromptu. And I didn't mean I wasn't going to address suspension, just that I had already decided what I was going to do there. And I did finally figure out a launch that works on our surfaces. Second gear and slip the clutch tends to work very well.
Old 05-18-2018, 10:23 PM
Nick.H's Avatar
If you want good mileage out of a DR, I recommend getting a Nitto 555r. If you aren't worried about mileage, the nitto NT05r is good, so is Mickey Thompson. Size will be up to you, but I recommend a small wheel (15-16") and a 275 drag radial. Best of luck and let us know what you end up doing
Old 05-21-2018, 05:27 PM
slowpoke96z28's Avatar
15x4 in the front on a full weight car? did they see street use or just track?
Old 05-28-2018, 02:37 PM
Nick.H's Avatar
both. Car wasn't entirely full weight either. Never ran into any issues
Old 05-28-2018, 09:25 PM
oh ok. I only ask because it was recommended I get a 6" wide front runner wheel since im actually heavier than stock in the front and have to drive on crap *** Dallas streets and freeways. Just wondered if you were in the same boat but getting away with a 4".
Old 05-28-2018, 09:55 PM
ThoR294's Avatar
I had 315 NT05Rs on 17x9.5" c5z06 wheels. way too much power for my boat anchor. i sold them because it was way too much tire. not much bulging, but as said here, a sticky 275 tire should be enough.
NT05rs are apparently skinny, so thats why the 315s fit. just had to make some love taps in my wheel well
Old 05-29-2018, 12:11 AM
Nick.H's Avatar
if you DD the car I wouldn't get a 4" also being heavy doesn't help
he only drove the car a couple times a week
Old 06-04-2018, 03:07 PM
Oh ok thanx. The iron block and power adder I know make the front heavier, and every path on routes I can take to get to the track/street spots are horrible. The buckles in the roads move too, so you try to dodge where it was the last time on that road and BANG, wheel or k-member smacks the ground. They do try to fix them, but a month later, it's buckling or potholed again. Bad soil I guess..
Old 08-14-2020, 02:43 PM
LT1DG's Avatar
Hey I understand where you coming from about the weight.
I'm running some 98 corvette rims. Fronts 275/40r17 and rears 275/35r18.
​​​​​​​The rims are super light tho, lighter then my oem abs rims which is crazy.
