Cold Weather Traction - “Summer” and “All Season” Tires
In general, does traction of most summer performance tires deteriorate significantly more than all-season tires as temps drop below the 50’s?
I am still running the OEM Goodyear Eagle F1 GS tires on my 98 TA. I am not eager to replace them. However, I picked up a small screw through the tread of 1 – tire. Since Discount Tire would not service it due to age, I plugged it. I am slowly evaluating tire replacement options. My driving is all street, conservative, ~98% dry, no snow. <1k miles/year and <~420HP. However, I do drive ~April-November in MI, so I see a temperatures as low as the 30’s. Should I stick with “All Season” options like the BFG G-Force Super Sport A/S; BFG G-Force Comp 2 A/S; and Goodyear Eagle F1 Asymmetric AS?
Thanks.
Thanks.
If you plan on regularly driving it in temperatures <50°F I would definitely recommend a high performance A/S like the ones you mentioned.
This video helps drive home the reasoning behind it. The performance differences shown in this video between an A/S and winter tire are even greater compared to a summer tire in the same temperatures.
As you can see in the video around the 40-50° point the A/S and winter tire performance differences aren’t huge. The summer tire however would start to look more like the 0° temperature comparison.
BassAckwards, seen the video before, but watched it again. Thanks.
HCI2000SS, yes. "098" DOT date code. ~26k miles. Tread depth still ok. Absolutely no cracking. Some cuts in the tread area though. Not real happy about plugging the 1 tire. If not for the cuts and plug, I would likely be quite content running them for another 10+ years with my conservative driving and low miles/year.
If you've never tried them in the winter its hard to believe just how good the new stud-less ice tires are,,
Have a AWD BMW that normally has Continental DWS tires on it, tried some X-Ice and WHOA!
The DWS were really really good, car was like a snowmobile,,, on ice the X-ice tires its just that much better..
Scary amount of traction..
The DWS are so good I haven't popped for another set of rims yet for the ice tires but considering it..
Get a set of the same size Conti winter tires on some used BMW rims and it would rock.
Tires over about 5 years old are a bad idea.. They are harder, more brittle and the interior liner is getting old.
You can't see the stuff thats aging. The exterior can be perfect.. and things in side the tire carcas can be shot..
Synthetic belted radials are really bad for aging.
About the only reason a modern tire fully blows out beside extreme damage is age.. You can't see whats wrong.
YMMV..
YMMV..
