LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   Help me decide on what tires (https://ls1tech.com/forums/wheels-tires/1908484-help-me-decide-what-tires.html)
Big bird55 10-11-2018 11:32 PM
Ok so im fixing to need new tires for the racestars that are on the Trans AM. It has 275/60r15 on the rears and a 25.7 tall front tire. Needless to say it throws the abs inop, tcs, and brake lights because of the size difference. However when it does that I feel like I have almost no brake pedal at all.
I like the 28 in tall tire on the back but since we cannot run a 28 on the front from what I have seen I'm leaning to a 275/50 just so I do not the tire size difference issue. Normally it wouldn't bother me but my mother sometimes jumps in the car and I do not want to take any chance with the brakes being so weird (the ta stays back home while I am at college). Thoughts? And any pictures of a 275/50
Also is the brake thing normal or should I investigate. When we swapped motors we pulled the k member and I took it to a shop to have them purge the abs system of air.
Big bird55 10-14-2018 07:09 PM
Bump ?
Big bird55 10-22-2018 12:07 AM
Bump... any help guys
Chris Paveglio 10-22-2018 07:59 AM
Sorry I can't really read your first post and understand what you need. Its confusing.
Big bird55 10-23-2018 03:48 AM
wow I did not even realize how messed up that post had been
fixed it
Big bird55 10-28-2018 06:20 PM
bump?
Big bird55 11-07-2018 08:24 AM
anything?
Launch 11-08-2018 01:35 AM
https://cimg8.ibsrv.net/gimg/ls1tech...ba0793bb1e.jpg
275/50 QT Hoosier. Just put them on 15x12's and they measure only 25" diameter. Too low profile for best traction but I had them for another car never used em so i'll use them up.
Launch 11-08-2018 01:40 AM
https://cimg9.ibsrv.net/gimg/ls1tech...c039213e8e.jpg
1hotroc 11-11-2018 09:04 PM
Originally Posted by Big bird55 (Post 19998299)
anything?
I had same problem with braking after putting drag wheels on my Hoss. I pulled the 40 amp abs fuse problem solved . No more death pull to the right under hard braking. When I put the stock wheels and tires back on abs fuse will go back in. Back to normal abs function
Big bird55 11-12-2018 02:28 PM
ill try that then and if that fixes it i guess ill go for a 28
© 2019 MH Sub I, LLC dba Internet Brands
