Well, f'd that up pretty well...(fixed)
Trying to put 18/19 c6 wheels on my 2000 trans am.
Everything I read said to get l.25" hub centric adaptors. So I do, and now the wheel won't fit on the adaptor flush to the wheel because I need 70.3mm instead of 70.5 I assume.
So good lesson learned the hard way. Gonna look good if it ever happens.
Spacer bolts flush to the rotor, wheel won't sit flush on the spacer.
The scratched surface is as far as the wheel goes on...
May try no spacerr and see if they fit just to run them
Rears are 285 35 19, spacers are only going on the rear.
