315's and rear axle bumpstop
I put some ZR1s with 315's on the back and if I raise the rear body, and the axle drops down, the top of the rim/tire hits the axle bump stop. it just barely hits. If I jack up the car, I raise the axle so the springs stay compressed and the bump stop is inside the rim area. Just wanting to know if others have experienced this. I could take the rubber stop off but I think that would be a bad idea. I was considering using a BFH to push the bump stop back some but there is a little support piece on the stop that might bend the wheel well a little too.
What you you guys think?
thanks, Kenny
thanks, Kenny
Originally Posted by joeformula
You could take off the jouncer and the aluminum plate that holds it on
on my 99 camaro it looks like the bracket is part of the wheel well.
Thanks for the info
