ZR1 wHEELS 17 BY 11 IN REAR
I just purchased zr1 replica wheels that are 17 by 11 in the rear and 17 by 9.5 in the front how hard will it be to mount the wheels in the back. My car is an 02 ss camaro with a one inch lowering kit, eibach pro-kit. The rear tires are 315 mm wide. Thanks and any knowledge would be appreciated.
Originally Posted by 5POINT7
You don't NEED an adjustable panhard rod. I'm lowered w/ 38mm ZR-1s 17x11 w/ a non-adjustable panhard rod w/o problems.
Just roll the lips, and BFH mod and you'll be OK.
how hard it it to aquire one and what is the cost
? is it an aftermarket product or do some cars have them already
Originally Posted by TooSlow02
Firebird rear wheel wells are bigger than Camaros. That little bit of room makes a pretty big difference. With the 36mm ZR1 offset (50mm is the Grand Sport) the wheels sit farther out away from the inner wheelwell, so an adjustable panhard rod isn't needed (on a Firebird). With the 50mm offset, it's required 99% of the time on a lowered car. You can try running without one, just check frequently to see if it is rubbing (you'll hear it).
The Firebird has the same outer wheel house as the Camaro, therefore they have the same demensions/clearance. If you look at the pinch weld in the front of the wheel house there is a wide spot that has been painted black from the factory. this is there because of the deep recess in the body side of the Camaro that the Pontiac does not have. But it still uses the Camaro outer wheel well so the gap had to be filled in, the factory tried to hide this by painting the erea black. One of several ways to save money.
