strippin and polishin zr1`s
Old 04-04-2005, 11:56 PM
juicedSS's Avatar
Default strippin and polishin zr1`s
hey guys how hard would it to be to strip and polish zr1`s. has anyone done this?
Old 04-04-2005, 11:59 PM
Onyx Z's Avatar
I wouldn't do it, waaaayyy too much work. It is A LOT of work.
Old 04-05-2005, 01:33 AM
Eugenio_SS's Avatar
did it... pix in signature.
did it because I hated the finish behind the spokes of the polished ones... was rough aluminum... the painted ones were smooth everywhere.
I basically remove the clear/paint with aircraft remover.
Make sure to use it in a well ventilated area... and the warmer the weather, the better the chemicals will do its work.
I then proceeded to wetsanding the wheels and clean them.
did it in 3 different steps, getting into finer and finer granularity.
Once done, polished it with Mothers compound.
I was **** and took my time... was winter... so it took me roughly 10-15hrs /wheel... all elbow work... pix in links in signature
Hope this helps.
p.s.: the center cap is chrome as well as the lugnut covers.
Old 04-05-2005, 01:47 AM
juicedSS's Avatar
thanks eugenio_SS i have done some before i just wanted to make sure these werent too big of a pain in the *** to do
Old 04-05-2005, 10:37 AM
SlowTA's Avatar
it is a huge pain in the *** to do i wouldnt recomend it
Old 04-05-2005, 12:00 PM
juicedSS's Avatar
well ive alredy done this to other wheels it isnt that bad for me cuz ive had a lot of experience polishin wheels
Old 04-05-2005, 03:22 PM
RomanK's Avatar
Where's Fayette? Im in Bham and just got some ZR1's but they look like ***, Pm me with your results and a materials list if you dont mind
Old 04-07-2005, 11:34 AM
93TAWicked1's Avatar
Hope this helps.
Damn if I would have seen that I may not have sold my stock Z06 wheels. I know with them you can get the face and lip professionaly done pretty cheap but then it would be elbow grease for the inside of the spokes.
That looks amazing!!! Hey did you get that SLP dual dual OK you never got back to me on it and I just remembered it, I can't tell from the pics if its on there or not
Old 04-25-2005, 04:09 PM
Eugenio_SS's Avatar
I actually tried getting the Y-pipe and SLP duals in there... buut the Y-pipe would hit everywhere... maybe due to convertible.
Ended up staying with true-duals... gave the SLP-duals to a friend.
am modifying the true duals to accomodate cats, mufflers after the axle, and putting electric-cutouts before cats.
