removing rim
Old Sep 8, 2005 | 05:34 PM
Kanes2413's Avatar
Default removing rim
how do i take the stock abs rims of my t/a?
Old Sep 8, 2005 | 06:09 PM
felton316's Avatar
Not sure what you're asking here. Can you explain it a little better?
Old Sep 8, 2005 | 07:19 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
You mean pulling the wheels off? All you need is a jack and a 19mm socket w/breaker bar or crossbar with a 19mm end for the lug nuts. 19mm socket will also pull the lug caps off.....
Old Sep 8, 2005 | 07:22 PM
s346k's Avatar
and that pos key used on the locking lugnut. if you don't have that key, get a good 12 pt 20 mm socket and beat it on with a bfh. i've had to do that...it works well.
Old Sep 8, 2005 | 07:27 PM
RPM WS6's Avatar
Good point, I forgot about that because I pulled my locking ones off as soon as I got the car and swapped them with regulars. They are a pain to deal with if you take the wheels on and off a lot....
