I think I goofed... 18x10.5 up front?
So far I'm the highest bidder on a set of C6 rims...
Well...the problem is I just noticed the front are the same size as the backs...18x10.5, both 56mm offset)
Am I screwed?
I hope someone outbids me lol
Am I screwed?
I remember seeing a z28 with 18x10.5 z06 wheels all around. I think it had the same offset too? I'm pretty sure they work, but if you do get outbid just don't bid again...
I have 18"x10.5" with an even deeper 58mm offset all the way around. They fit perfectly, no spacers and no rubbing. 56mm offset will be no problem. My friend put some 18"x10.5" Z06 wheels on his TransAm with no problems, too. They were 56mm offset.
Some pics of mine:
Some pics of mine:
So 58mm all around would be ok? There's that Sticky by XztaZ28 that says 56mm would be max, or does it depend on the type of wheel? ie C6 vs. Z06 motorsports? If 58 will fit, then FAQit, I'll go with 18x10.5 all around motorsports.
Originally Posted by TooSlow02
They fit great. I highly recommend picking them up.
You may have to re-center the rear with an adjustable panhard rod. The fronts will still fit fine. My friend's T/A is dropped with Eibach Sportlines, which ended up lowering it just over 2" in the front and 4" in the rear. He's also sitting on 18"x10.5" all the way around. He has no issues at all, even without the adjustable PHR. You shouldn't have any problems.
The torque arm won't have an affect on the PHR. The panhard rod is the lateral locating member for the rear axle housing. It's the stamped metal bar that bolts to the driver's side of the rear axle housing and to the passenger side of the body, running behind the axle to control side-to-side movement. Due to GM's "production tolerances" most rear axles in F-bodies aren't precisely centered to the car body. That means that one tire will stick out away from the car farther than the other. The difference is slight, though. But a lot of times when you go with tires 295 and up you have to buy a PHR that's length adjustable to center the rear axle (especially if the car is lowered). Otherwise one tire might rub on the inside of the wheelwell, and the other might rub on the lip of the quarterpanel. They aren't expensive and very easy to install. Well worth the money. There are quite a few companies that make quality pieces (UMI, BMR, LGM to name a few), so search around.
