burnout nitto's this gonna sound dumb, i tried to do a burnout with the new nittos i dumped it around 4 and hit the brakes all the car did was hook and the whole back end swung out and then car started to bog and almost die... what the hell did i do wron had no problem on street tires doing a burnout |
The Nittos are softer than most street tires and stick a heck of a lot better |
street tires = burnout drag radials = sticky If you could burnout Nitto DR's at will, don't you think they would be a lot less covetted for drag racing? :poke: |
hmmm.....bogging the engine down w/nittos doing a burnout? Sounds like you need more power. |
hahaha u suck at LIFE!! |
Mine burnout even if I don't want them to wanna trade lol. |
Originally Posted by Detroitmuscle Mine burnout even if I don't want them to wanna trade lol. |
Originally Posted by LastHawk02 this gonna sound dumb, i tried to do a burnout with the new nittos i dumped it around 4 and hit the brakes all the car did was hook and the whole back end swung out and then car started to bog and almost die... what the hell did i do wron had no problem on street tires doing a burnout |
Try doing the burnout in second gear. |
yeah i figured, guess ill just dump it higher |
4k should break them loose no problem...to heavy on the brakes maybe? |
Originally Posted by 93formto98T/A hmmm.....bogging the engine down w/nittos doing a burnout? Sounds like you need more power. |
| All times are GMT -5. The time now is 03:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
