LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   315's on front? (https://ls1tech.com/forums/wheels-tires/610494-315s-front.html)
speedyss Nov 17, 2006 08:29 PM
315's on front?
Of course on a 11" wheel, but will they fit on the front with moding if needed?
michaelg589 Nov 17, 2006 08:38 PM
Do search!!!!
Theres been at least two other posts about this exact same thing. :judge:
And yes it is possible with I think only a 3/16 spacer and some longer wheels studs.
Oh and definately not something you want to be driving every day :drive:
michaelg589 Nov 17, 2006 08:45 PM
Here's one....
https://ls1tech.com/forums/showthrea...ighlight=17x11
DONAIMIAN Nov 17, 2006 09:30 PM
http://www.frrax.com/rrforum/index.php?showtopic=2922
anotherreject04 Nov 18, 2006 12:53 PM
maybe im thick headed but why 315's on the front?
dailydriver Nov 18, 2006 01:43 PM
Autocrossers (in Street Prepared class and up) and open trackers (road course) do it all the time, usually with VERY sticky R compound tires or slicks. It's all about the left-right and turn in/exit/transitions. Yes, most on here would NEVER understand it, as they are ONLY concerned with straight line speed and prove it by driving around on the streets with skinnies and no front swaybar. But yes, it would be just as radical to drive around full time on the street with sticky 315s up front. Maybe some just think it looks wicked in an anti-skinny sort of way, even with a street tire on the 11s. To each his/her own I guess.
michaelg589 Nov 20, 2006 11:00 PM
Some people think its stupid. But F-bodies are heavy vehicles. A 315 is not all that ridiculous. I would assume you WOULD need a huge tire up front to be able to take corners at extremely high speeds and prevent a 3500+ lb car from understeering.
© 2026 MH Sub I, LLC dba Internet Brands
