LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   Question about 315's (https://ls1tech.com/forums/wheels-tires/612326-question-about-315s.html)
93BlackZ28 Nov 21, 2006 06:19 PM
I got the 1" lowering spring from hotchkis and i was wondering what id have to do to get 315's to fit. Or would i not have a problem with just a 1" lower? Thanks.
strippedSS Nov 21, 2006 08:39 PM
You will be fine with a 1" drop on 315's. Unless there is some wierd wheel offset going on.
97 SS LT4 Nov 21, 2006 08:52 PM
I just put on a set of 315 17" 3 days ago. No problems after the car is lower back onto the axle. My car has the SLP lowering kit. I did have to punch in part of the inner fender liner with a 10# hammer for better clearance.
JaSSon00 Nov 21, 2006 11:57 PM
I have the same springs, and did 315's over the weekend. I rolled the fenders and hammered the lower inner fender well.
Thats all you need to do.
strippedSS Nov 22, 2006 08:42 PM
I'm lowered 1.5" on 315's with no hammering or rolling.
Urban Legend Nov 22, 2006 10:46 PM
50mm offset also helps.
© 2026 MH Sub I, LLC dba Internet Brands
