LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   cheap 15's? (https://ls1tech.com/forums/wheels-tires/622954-cheap-15s.html)
s1ck s0n Dec 12, 2006 01:19 AM
cheap 15's?
id like to pick up some 15" rims because my g/f has a buy one get one free mickey thompson coupon and theres only the one 16" size. i dont care what they look like as long as theyre cheap. and i guess it wouldnt matter if they stuck out a little bit as they would be track tires only.
00formLs1 Dec 12, 2006 01:32 AM
i would just get the 255's there are cars making 500-600 who are hooking with them
cheapest would be pro-stars but they are hard to come by now since they are not made any more. if you get 15x8 you need a 5.5 basck spacing and if you get a 15x10 a 7.5. anything less and they will stick out. ur also going to have to gring the calipers a bit.
s1ck s0n Dec 12, 2006 05:25 PM
hmm, ok. i guess ill be going with the 16 inchers. thanks!
bad2000z Dec 12, 2006 05:56 PM
Weld Draglites, cheap, look cool, lightweight, 15x8 5.5 backspace - they wont stick out, but you do have to do some grinding. You can get them cheap from Summit or Jegs. Good luck!
00formLs1 Dec 13, 2006 12:07 AM
the drag lites are also limited. a set of bogarts would be sweet but be prepared to pay 1500 for a set. but they just bolt-on with no grinding.
bad2000z Dec 14, 2006 12:00 PM
What do you mean by limited? Summit and Jegs keep these wheels in stock all the time. Summit has the pro stars in stock. I did hear American Racing bought Weld Racing, but the pro stars have not been discontinued - yet.
00formLs1 Dec 14, 2006 12:50 PM
there have been a few member who ordered them and sumit or jegs didn't have the size or they only had a set or two left.
© 2026 MH Sub I, LLC dba Internet Brands
