c5 z06 rims, wheel spacers
Old 12-14-2006, 03:11 PM
NBM01Z's Avatar
Default c5 z06 rims, wheel spacers
Any one running wheel spacers in the rear with 18x10.5 58mm offset c5 z06 rims? If so please post some pics and size spacer. Preferrably of a Camaro, Thanks
Old 12-14-2006, 03:54 PM
pro2low's Avatar
im trying to figure out Z06 rims to put on my car i found a 53mm offset from lm performance they are on sale right now too! im just trying to figure out what i would need to do to fit a 315!
Old 12-14-2006, 05:14 PM
mikep's Avatar
53mm should be perfect. What do you guys think?
Old 12-14-2006, 05:18 PM
mikep's Avatar
Lets say if you want to run 295/35/18
Old 12-14-2006, 05:55 PM
f50nut's Avatar
I wish I knew the offset of mine..I am using a 5/8" spacer and they fit perfect with 295's
Old 12-15-2006, 05:05 AM
Race your car!
JL ws-6's Avatar
did you have to put a spacer on or will they fit without it? Also, how long are the studs... I have the longer ones that moser sells with the 12 bolt, I can still use teh stock wheels and the plastic caps but they are definately longer then stock was, probbaly a 1/2 inch.
Old 12-15-2006, 08:50 AM
red87iroc's Avatar
I just installed 10.5" Y2K wheels with 58mm offset on my 94 TA. They fit fine, no rubbing. But I may need to use either the BFH mod or install 1/8" spacers when I lower my car over the winter. I am hoping I can just center things with the adjustable PHB.
The 5mm difference between 53's and 58's only equals about .1968", or between 3/16" and 13/64". So a 3/16" spacer would make the offset almost the same as a 53mm wheel.
Old 12-15-2006, 10:55 AM
NBM01Z's Avatar
i'm already running the 18x10.5 58mm os on the rear, but i'm interested in putting around a 1/2 inch spacer (i think). Everything fits fine and i'm lowered, i just want a more aggresive look. So if anyone has done this (with this wheel) please chime in and post pics. . I just figured it would be a common thing due to the high offset of these wheels.
f50nut can you please post some pics,
thanks
Old 12-16-2006, 11:42 AM
NBM01Z's Avatar
nobody?
Old 12-16-2006, 02:51 PM
michaelg589's Avatar
I just bought C6 wheels. the are 18x10.5" for the rear. they have a 58mm offset. I test fitted them without the tires and they hit the bumpstops, but just barley. other than that, they were fine. I bought 5/16" spacers and they fit perfect now. (without the tires). they dont hit the bumpstops. But it looks like the tire might end up bein kinda close to the fender lip. Not sure yet. Waiting to get tires after X-mas. the 5/16" spacers bring the 58mm offset down to about a 50.1mm offset.
Old 12-16-2006, 04:34 PM
f50nut's Avatar
sorry it took so long..here's a few, i tried to get a couple that show how far the rears stick out. they don't over hang the quarters at all
Old 12-16-2006, 05:20 PM
NBM01Z's Avatar
thanks f50nut thats more of the look i want, i'm thinking of running the
Baer Billet Aluminum spacers from thunder and thier arp 2.5 studs. What are you running?
michaelg589 did you jack up your car by the rearend? If so they should clear.
Old 12-16-2006, 05:27 PM
f50nut's Avatar
I'm running the longer studs and spacers I picked up on ebay. I milled them down to the size I wanted.
Old 12-17-2006, 12:18 AM
At first I didnt jack it up by the rear (I actually forgot about having to do that) and it hit the bumpstop. When I jacked it up by the rear it didnt hit, but if it hits anywhere at all with all of the suspension travel, I'm not cool with that. So i bought the spacers to make sure it will never hit. I daily drive my car and I cant be worrying about something like that. Basically, if theres a chance that I could accidently hit a bump too fast and the rear travels enough for the wheels to hit the bumpstops, I'm putting spacers.
Old 12-17-2006, 12:45 PM
Race your car!
JL ws-6's Avatar
do you know hwat thickness you milled them down to? I have a set of c5 z06 wheels (stock oem ones) I wanna put on, I'm definately gonna have to slug a spacer in there and hit the inner wheel well in a little I figure.... do you know how thick you milled the spacers you are running down to? I have the longer studs that moser puts on the 12 bolt, they're about a 1/2 inch longer then the stock ones.. so I think a 1/2 inch will be perfect, and will cut down on the beating I have to do on the inner bfender.
Old 12-17-2006, 04:05 PM
f50nut's Avatar
I'm pretty sure they're 5/8", but I'll double check for you.
Old 12-18-2006, 04:46 AM
Race your car!
JL ws-6's Avatar
Thanks. I was gonna order a set this week.. either a 1/2 inch set, or a pair of 5/16 and a set of 7/32, it would add up to a bit more then a 1/2. I'm still probably gonna have to tap that inner area in which I'm o.k. with.. I just don't want to have to blast the hell out of all of it.
Old 12-18-2006, 10:12 PM
f50nut's Avatar
Okay mine are actually closer to 1/2". Before the spacers the rubbing was minimal on the passenger side only, and might have been corrected by an adjustable panhard rod (but it still would have been close).
Old 12-19-2006, 12:32 AM
NBM01Z's Avatar
thanks..... you didnt happen to measure the offset too did ya?
Old 12-19-2006, 07:48 AM
f50nut's Avatar
I believe they're 58mm in the rear
Quick Reply: c5 z06 rims, wheel spacers
