front skinny to go with MT 325/50/15 I just ordered some bogarts and MT 325/50/15 DR for my 99 z28 and am looking for tires for the street/strip for my 15x4 fronts. The car is not a daily driver and will not see the rain. I do plan on driving it some on the street including 2hr one drives to the track. Whats a good tire to use? I have heard differnt things from differnt people. |
I know they're a little on the heavy side, but how about some M/T Sportman fronts, the 8-ply ones? If you're going to be driving to the track with them on and cruising around on them, I'd go with a tire with a proper load rating. |
I had good luck with my Kumho Powerstar 165R15s. Like $24-26 a piece too. |
Originally Posted by LS69TA I had good luck with my Kumho Powerstar 165R15s. Like $24-26 a piece too. I was looking at those. Im just worried if they can handle the weight when the front end comes back down. |
Hmmm..I didn't have to worry about that. If your're pulling the tires I'd go with the 8-ply Mickey T's. |
Originally Posted by minytrker I just ordered some bogarts and MT 345/50/15 DR for my 99 z28 and am looking for tires for the street/strip for my 15x4 fronts. The car is not a daily driver and will not see the rain. I do plan on driving it some on the street including 2hr one drives to the track. Whats a good tire to use? I have heard differnt things from differnt people. |
i think he means 325's... Im running the 8 ply sportsmans up front... they are nice |
yep was a typo |
I use the MT S/R radial 26.00x6.00-15. It's a 4 ply Polyester/fiberglass radial. It's rated at 990lbs @ 35psi. They weigh in only slightly heavier than the 26X7.50-15 8-ply sportsmen's (19lbs vs 20lbs). I didn't weigh them myself. Those are printed specs on them. My car weighs in at 3850lbs street trim and 3730-50lbs race. The tires don't bulge, are stable at speed, and I haven't had any issues with them. http://static.summitracing.com/globa...mtt-6651_w.jpg # Sportsman S/R Radial26'' x 6'' - 15''LT 672-6652 Tire Overall Diameter: 26.0'' Tire Tread Width: 5.7'' Tire Section Width: 6.5'' Wheel Diameter: 15'' Spec Wheel Width: 4''-5'' Tire Weight: 19.7 lbs http://www.mickeythompsontires.com/s...em=SportsmanSR http://www.fastlsx.com/forums/attach...4&d=1130889954 http://i103.photobucket.com/albums/m...rontlowhoo.jpg http://i103.photobucket.com/albums/m...dehooclose.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
