Weld/draglites racing wheels backspacing?
Old 04-13-2007, 10:19 AM
brienjustin's Avatar
Default Weld/draglites racing wheels backspacing?
Hey everyone. I am looking to get 2 15x4 front drag wheels and 2 15x10 rear drag wheels. Probably weld or pro star. Do you guys know what the correct backspaing is. I have heard 7.5", but i dont want to have any rubbing issues, and i like it whhen the tires stick out a little bit, so i am looking for some help. Thanks
Old 04-13-2007, 05:59 PM
RZRSEDGE's Avatar
The fronts are should be like a 2" backspacing, my 3.5" are 1.75". On the back, everyone that I've read about with 10" wheels run a 7.5" bs like you said; but you may go with a 5.5" bs if you want them to stick out. My personal opinion is that they would stick out too much, but to every man his own. Hope this helps you out some!
Old 04-13-2007, 06:31 PM
SIC AZZ WS7's Avatar
I was thinkin of get those same wheel, does any one know what the bolt circle sizes is?
Old 04-14-2007, 12:15 AM
Maybe i will go with a 6.5" BS on the rear. I know the bolt pattern is 5 x 4.75. I just dont want to have rubbing issues. I am wanting to get drag tires and skinnies for the track, and then put on my street tires for cruising around town. I will look around for some wheels with those backspacing and sizes. I know there is a guy on ebay that builds them to your specs. Do you have any pics of your car with these wheels/tires on it?
Old 05-05-2007, 12:07 PM
jonm3456's Avatar
Default Weld pro stars
I currently have 2 Pro Stars 15x10 7.5" backspace. Weld #96-510284. I am going to mount these wheels on my car with MT ET Street Radial 275/50/15 tires this week. I will be sure to make a post with how they fit. Anyone know the deal with pro stars in the front?? I guess you need a wheel spacer?
Old 05-07-2007, 08:44 PM
jonm3456's Avatar
just mounted my prostars in the rear tonight. They fit with about 1/2" clearance between the sidewall and the inner fender. I set the tires to 32psi. Good enough for me, no rubbing!!!
Old 05-08-2007, 11:02 AM
can you get some pics up?
Old 05-08-2007, 11:25 AM
LT1
LT1's Avatar
does the 15X10 with 7.5" backspacing stick past the outter fender? does it need the fender lip rolled if lowerd?
Old 05-08-2007, 11:29 AM
LS69TA's Avatar
6.5" on a 15x10 was dead even with the fender on my '01 WS6.
Old 06-11-2007, 08:37 PM
jonm3456's Avatar
Default Prostar 15x10 How to make it fit on rear...
I finally finished up installing my Prostars 15x10 7.5" backspace on my car tonight. You will need to:
Grind rear calipers down about 1/4" so the rims don't rub on the calipers
Install 3.25" ARP wheel studs so you can properly tighten the wheels
Use shank style open ended lug nuts of you want to drag race with them
Also i used a 5/16" wheel spacer for a little extra clearance
There is no inner fender bending, hammering necessary if you do what i did. Hope this info helps out...
Old 06-12-2007, 11:00 PM
LT1
LT1's Avatar
thank you Jonm3456 excatly what i was wanting to know.
Can you post few pictures with your Prostars on.
Old 06-14-2007, 05:22 PM
nikon1999's Avatar
i have a set of 15x10 prostars myself w/7.5" backspace.. i've ground down a lot more than a 1/4" using a 5/16" spacer and still have fitment issues
Old 06-14-2007, 05:23 PM
nikon1999's Avatar
any chance you took some pics of the calipers when you were done? thanks!
Old 06-14-2007, 08:20 PM
boostedbuford's Avatar
I just put my prostarts 15x8 w/ 5.5 backspacing on, I used an angle grinder but dont be suprised if you spend 6+ hours grinding on the calipers...its a huge PITA
Old 06-19-2007, 11:41 AM
LT1
LT1's Avatar
alright im a bit confused, which backspacing fits good with out spacers, 6.5" or the 7.5" and what about a 7" has anyone tried it?
Old 06-19-2007, 11:48 AM
LS69TA's Avatar
Both work without spacers. You have to grind with the Welds regardless of whether you use spacers or not. The 6.5" fits better on the T/As due to the rear quarter panels being a tad wider than the Camaros. Weld doesn't have a 7" bs.
Old 06-26-2007, 04:28 PM
nofearracing28's Avatar
What size spacers are needed for the front?
Old 06-26-2007, 04:48 PM
LS69TA's Avatar
5/16 and longer studs.
Old 06-26-2007, 04:59 PM
and 5/16 spacer for the rears too??
Old 06-28-2007, 12:38 PM
LT1
LT1's Avatar
which lug nut is better open or closed end 12mm X 1.50 ? i wont be running spacer with longer stud's. im going to grind till it fits.
Quick Reply: Weld/draglites racing wheels backspacing?
