Fitment - 275/40/18?
yes they will. i have had them for more than a year. you will have a little rubbing on the front wheel well, but only on sharp turns, nothing that will hurt the tire. make sure you calibrate the speedo for this new tire size
I really don't want 35s. Not enough sidewall for me since my car isn't lowered. And I cant lower it either since my y pipe scrapes as it is.
I know a 35 would work better, but would 40 work?
Thanks.
Thanks.
ya 40 will "work" its just not "right". If interested. I have 2 275/40/18 goodyear F1 EMTs 1 probably has about 90% tread left the other has 60ish% tread left. These are $414 per tire. I'd probably sell them both for ~$300.
http://www.discounttire.com/dtcs/fin...&ar=40&ct=null
Thanks
i have 275/40/18 on all four's with 18x9.5 wheels and the do not rub what so ever...IMO i think they look better wotha 40 sereies aspect ratio rather than 35. Its nice to see a car have a little bit of rubber to the tires which also helps the car to ride a little smoother on the streets....another plus for the 275/40/18 over the 35 is that it will fill out the wheel well better than the 35 and the car will look good like a complete 4x4 on stock springs...im actually happy with my ride hieght rate now....
Originally Posted by Jscotty
Can you be a little more specific as to why it wouldn't work "right" please? Would it be because it would rub on a sharp turn? Or would it just not fit at all(Which I doubt would be a problem)?
Thanks
Thanks
