To make sure I'm 100% sure on 17x11's
Hi guys,
I got my 17x11's in today and was curious as to how they would fit. I used a conventional lift and put them on, and when I dropped them down the bumpstops were pressed against the tires which scared me.
I've been reading and saw that people suggested using a 5/16" spacer or so? The only spacer I can find is this:
http://thunderracing.com/catalog/?ac...vid=4&pcid=215
I'm not sure which one I need however.
I have also read that I need to jack the rear end up with the differential housing as opposed to the traditional lift method?
The car is a 1997 Z28 and the tires are 50mm offspaced Black ZR-1's.
If anyone could confirm or give me advice I would be beyond grateful! I hope everyone has a safe weekend.
will jacking up the differential housing keep the axles at their usual height instead of lifting it all?
I guess I'm just a little nervous of hitting a bump and puncturing a tire or something with one of the bumpstops.
ya, It will keep the bump stop closer to the rotor instead of letting the wheel droop.
I grinded the bumpstop completely off on a prev car. I will never do that again.
what fireman said will work, but its not needed.
Update:
Followed what Donohue96M6Z28 said for the rears, and the bumpstops are under the top of the sidewall/under the top of the rim! Fits perfectly so far! Put on the backs and took a cruise around the neighborhood and no rubbing yet..so it looks like this is def. the trick if you have 50mm offset wheels in the rear!
Thanks a ton Donohue96M6Z28!!
yup had the same problem but had the tire shop go from the differational and it solved it and no rubbing .. i may down the road mess with the bump stop when i lower my car a bit
I don't have that problem on my car. My bumpstops are not cut. I have adjustable LCAs and a adjustable Panhard bar. My roomate who has the same thing as me but on a 96 Z28 had to cut his bumpstops to get his 17x11s to fit.
I had to BFH the front of the fender wells but some automotive underbody paint helped so you don't notice it when i take the wheels off.
Still no problems but someone said that if I go over a hill or a bump I run the risk of blowing a tire out since the axle will allow the bumpstop contact with the tire..
has anyone had this problem? I went ahead and removed the two 13mm bolts and took the bumpstop off, but is that enough or do I need to worry?
