Will 315's work?
Old Nov 17, 2007 | 07:56 PM
Funkybird's Avatar
Default Will 315's work?
I'm wondering if I can fit 315's on my 18x10.5 zo6 motorsport wheels, does anybody know? Currently i'm running 295/35r18s just fine but I have heard I need a different offset to fit them?
Old Nov 17, 2007 | 08:33 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
This is from the sticky
18"x10.5" +50 to +53 mm. Higher than 53 mm will require the BFH mod. 285/35R18s thru 315/30R18. Over 295 may require rolling the fenderlip and will need the BFH. +58 mm is the typical available offset for the Z06 replica, which will require a little BFH and/or a small spacer.
