OEM Z06 Wheels / tires size q....
Just picked up a set of 4 17x9.5 OEM Z06 wheels. What size tires should I use on them? The guy who sold them said 275/40/17 's Thinking about the 275/40YR17 Goodyear Eagle F1 GS-D3. Tirerack.com has them for 790 shipped to my front door. Would these work? The offset is fine for these wheels to mount w/o spacers correct?
Thanks!
-Andy
Thanks!
-Andy
Re: OEM Z06 Wheels / tires size q....
Those tires would be great, I've heard ALOT of good things about the new F1 GS-D3 tire. And yeah, 275/40-17 is the right size.
(You can go 285/40-17 if you wish... little bit wider, little bit taller... only like $3 more per tire.)
OEM Z06 wheels should bolt right up, so sounds like you're good to go!
