18's all around??
Old Jan 3, 2008 | 01:34 AM
DarkLoneWolf666's Avatar
Question 18's all around??
I Have the Z06 Vette rims on my Camaro. 17's on front and 18's on rear. Looks like i notice late that my alienment was out and the side of the front tire is balding out. I can't rotate these tires unless i go all 17's or 18's. My rears still have full tred. So i was thinking. Should i put 18's in my front??? I mean who in here has 18's all around on Camaros??
Old Jan 3, 2008 | 01:35 AM
Silver UltraZ's Avatar
40% of people run 18" on here. Just do it. the step down look looks like **** IMO
Old Jan 3, 2008 | 01:42 AM
what you mean step down??? as in all 17's?
Old Jan 3, 2008 | 08:31 AM
Xsta Z 28's Avatar
18" all four corners . . . different widths though. Never cared about alignments on my toy cars.
The change in wheel OD IMHO looks wierd on F-Cars since the OD of the tire needs to stay the same to keep ABS happy. So the front sidewall with a 17" wheel is taller that the rear side wall of a 18" wheel.
Old Jan 3, 2008 | 08:33 AM
whatsgrip?'s Avatar
17"__--18" <----you see it stepped down. 18" all around will look way better on a camaro.
Old Jan 3, 2008 | 09:00 AM
cookba's Avatar
i have 18" on all 4 with 275's all around as well. No complaints but i think on super sharp turns my fronts rub the wheel well a little.
Old Jan 3, 2008 | 09:04 AM
ls1leadfoot's Avatar
18's all the way around.....
Old Jan 3, 2008 | 09:34 AM
CALL911's Avatar
If you are asking just to satisfy your alignment problem, then I would say just stick with what you have, and get it aligned properly. It'll only cost you about $50 at most ASE certified shops. Even if you went 17's or 18's all the way around, you still would need an alignment done anyway. Depending on what you like, a lot of people have different tires for the back than they do on the front, meaning doing this wouldn't allow a rotation either.
Now, if you are asking from a cosmetical standpoint "which looks better", then I would agree that 18's all the way around look better than 17's on the front, and 18's on the back, but thats a decision you would have to make personally.
Old Jan 3, 2008 | 09:37 AM
CALL911's Avatar
Oh, and I also have 18's all the way around on my Camaro.
Old Jan 3, 2008 | 09:41 AM
cookba's Avatar
i think 18's help fill in the wheel well better too on stock height Fbody's as well.
Old Jan 3, 2008 | 09:45 AM
whatsgrip?'s Avatar
BTW sick car dude
Old Jan 3, 2008 | 04:49 PM
The Guz's Avatar
Go 18's all around.
