LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   M/T DR''s will break it? (https://ls1tech.com/forums/wheels-tires/855454-m-t-drs-will-break.html)
Blknight6989 Jan 30, 2008 11:12 PM
So before summer comes i plan on having LCA's,PHB,SFC's, A 4000 stall an 3.73's installed in my car along with whats in my sig. Now my plan is to burn off the Nitto's i have now at the speed inc open house( they still got some good tread so it outa be a show!:devil:) an pick up some M/T DR's for the racing season. Now my question is do you guys think it'll be likely i break my ten bolt with these mods and tires? It will mostly see street racing and maybe the track a few times. Also what rpm do you reccomend i leave from on the street? Any info or opinions are really appreciated.
crazydavez28 Jan 30, 2008 11:20 PM
your ten bolt WILL go if you race it... just make sure you have a buddy with a trailor.
Blknight6989 Jan 30, 2008 11:26 PM
Haha great! guess il have to make one of those! just how soon do you think that will happen with this setup? without like launching the F*** out if it? I already have a jar in my house thats labeled "12 bolt fund"
Detoxx03 Jan 30, 2008 11:26 PM
This scares me
Unstang Jan 30, 2008 11:43 PM
When I first got the 17" ET radials, my stock Auburn & 3.73s bit the dust from a 5 mph roll...Not real sure if it wasn't going any way.
With my new 10 bolt stuff I've ran 11.20s (on a small dry shot) & 11.60s-11.70s NA, nothing too deep into the 1.6x 60' times though. My current converter doesn't hit very hard & everything is fine with the rear right now.
I've been thinking about going to a Vig 3600-3800 the 10 bolt is one of my concerns.
Blknight6989 Jan 30, 2008 11:44 PM
Originally Posted by Detoxx03 (Post 8606408)
This scares me
My setup?? lol
DopeFedZ Jan 31, 2008 12:38 AM
I just busted my 10 bolt at the track this weekend. It also took out the sprag in the tranny. Stick to rolls or digs on the street but the track means death to your rear.
'Trust' Jan 31, 2008 12:54 AM
In an auto you should be fine, although your gears won't help keeping the 10-bolt together. I ran my blue TA (400 RWHP) with a stalled auto on ET streets several times at the track with zero issues. I'll be running the white TA this weekend, it makes more power (430 RWHP, should be 440 before the track) and will be on a lighter wheel but still ET streets, I'll let you know how it holds up
c0ncEpT Jan 31, 2008 01:36 AM
A friend of mine runs his H/C 4000 stall A4 car on stock ten bolt to low 1.6's on ET street radials at the track. Rear end has held up in his car to more than 30 passes. An auto car is much more forgiving on the rear end than a 6 speed car.
AFTICA Jan 31, 2008 07:56 AM
The 5th run on M/T radials broke the spider gears in the posi on a 1.60 launch with my 4000 converter and 3.73 gears. Made many runs on ET Street bias ply w/o any issues. The radials HOOK HARD.
skyhighsami Jan 31, 2008 09:53 PM
On a M6 car if you had a Line Loc what if you were holding the line lock and had the clutch at the sweet spot to kind of load the drivetrain a little while you kept the revs up for the launch? I am not sure if that makes sence but since you are on a 10 bolt you won't be side stepping the clutch at 6k so if you left hard but not through the roof would that work? I was thinking about that today
dirtdevil99 Feb 1, 2008 07:51 AM
Dunno skyhigh, it would probably help to keep a load on the drivetrain as opposed to just popping it hard. I sheared my driveshaft with a 5k dump on drag radials....Good Luck!
DopdBrd Feb 1, 2008 10:16 AM
I've always heard Automatics are A LOT easier on rear ends than M6's. You should be ok for a while with that ticking time bomb of a rear end.
BOLO Feb 1, 2008 06:11 PM
I'm running 4.10's, stock 10 bolt,3600 stall,MT 325/50 drag radials. Still holding up, even on the juice and hopefully will hold up for more runs this year. knocking on wood.....
wg871 Feb 1, 2008 06:14 PM
They need to finace 12 bolts lol
© 2026 MH Sub I, LLC dba Internet Brands
