m/t radials questions
Old Mar 3, 2008 | 06:14 PM
gr8one99SS's Avatar
Default m/t radials questions
anyone try these on a stock wheel? did you have to do any cutting on the bumper, inner fender hammering or bumstop removal.? and will i have to buy offset lca? thanks. i need new tires and these seem perfect.http://store.summitracing.com/partde...5&autoview=sku
Old Mar 3, 2008 | 08:21 PM
gr8one99SS's Avatar
no one?
Old Mar 3, 2008 | 08:47 PM
gr8one99SS's Avatar
i need something in a 27-28x10 to help hook up in a 3650lb car . has a 3600 stall and 150 shot.
Old Mar 4, 2008 | 06:29 PM
gr8one99SS's Avatar
has anyone tried either of the new m/t drag radial in 16" rims?
Old Mar 5, 2008 | 09:47 AM
DopdBrd's Avatar
Those should fit on a stock 16x8 inch rim. They say the recommended narrowest rim is a 8.0 inch so technically they should fit.
Now as far as them looking good.....that is another question.
EDIT: Also, being that tall of a tire they may rub on your inner fender due to the offset of the stock wheels.
Old Mar 5, 2008 | 10:41 AM
SSAbner's Avatar
you will have to "massage" the wheel well
Old Mar 5, 2008 | 07:50 PM
gr8one99SS's Avatar
thanks guys. I would like to run the wider tires but i dont know if i can massage enough fender and stock wheels arent wide enough
