Getting a good deal on 20's what do you guys think
Ok so i am getting what i think is a good deal for a set of 20x8.5 and 20x10 for the rear, the centers are titanium and it has a 2inch chrome lip...what do you guys think?
LS1TECH & Trucks Sponsor
It's a good looking wheel, but in order to make a 20x10 fit you will have to modify to an extent that requires you to change your myspace song to "Ima lift it".
I do like the wheels though, just not on an fbody for fitment issues along with the universal lug pattern that doesn't belong.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Those may actually look good. Good luck with the fitment. Some guys on here have 20s but I think they ride at stock height so if your lowered at all, i'd say forget it.
I think they actually might look good. Most of the newer sports cars are getting the big wheels straight from the factory now too.
One thing to consider... goodbye traction for sure.
LS1Tech Co-Founder
Those newer cars also have a taller tire diameter than our 26" tires. That means their sidewall thickness is still proportional to the larger wheel size. I've never seen a set of 20s on a 4th gen that looked right, every case would have looked better with 18s or 19s instead.
i personally won't go over a 17" wheel on my car, mainly due to the fact that 18" + tires start getting expensive really quickly, and also the bigger the wheel, the heavier the wheel.
the only way i would go with anything over a 17" wheel is if i was absolutely required to in order to get bigger brakes to fit, and even then i wouldn't go over an 18" wheel.
that wheel does look pretty sweet, but 20" is just WAY too big to look good on these cars.
